I like the diagonal boards. Flip the knife over so the shield can be read and close the blade so it's open about 45 degrees. Normally I would say turn the knife slightly so that the handle isn't exactly horizontal, but leaving it horizontal will create a triangle with the two boards. You'll fill the image, have interesting lines and both shield and etch can be read.
I rarely take photos of knives with the blades partially open, and usually only do so with knives that have blades on both ends (stockmen, scout knives, canoes, etc.)
I never partially open both blades on a single spring knife for pics and on multi spring/blade knives, when both blades on on the same spring are shown they either are both completely open or one is partially open and the other completely open to avoid putting undue stress on the spring, I like smaller blades with half stops it gives me more options for pictures.
For example, the Swayback Jack has half stops on both blades and 2 springs so I'm not stressing the back springs.
Fully agree, the writing should be correct for an open knife, a knife which is ready to cut. A knife being a knife. Always annoyed me. Or put the writing vertical like on the bolsters of the new 25's. That makes sense whether closed or open. Queen's shield being upside down is silly. It's a single letter, why not just align it vertically?The only question I have is who's bright idea was it to put shields with writing upside down? This has always annoyed me and if someone who made knives for me did this in the shop, the knife would not leave the shop till the writing was on the right way. The Tidiute above makes the problem jump out. Then after the first person did the shield that way, everyone else followed suit. Go figger! The proper orientation, to my eye, to display a knife is like the first photo, so you can imagine grabbing it and using it. I like pictures with the blade fully open so you get a better idea of blade/ handle ratio, and the angle of the cutting edge relative to the centerline of the knife.
I will never UN-SEE this image.
From this day forward every knife I see I will be looking for correct formating of the image.
I'm not even CLOSE to joking.
That said I prefer the bottom image with the slightly open blade.
Everything else has Something upside down. Damn you O.C.D.!!!
THANKS!![]()
Upside down text bugs me but that's not the only reason the second photo is better. Top photo knife is straight and lies parallel with the horizon, second photo is full of angles. Straight lines are boring, angles are more interesting. Why have the text upside down unless you absolutely have to?
And after reading this thread and learning about angles, I attempted this yesterday (apologies for the crappy quality of my phone cam)
Tried your recommendation, I do really enjoy your photos so figured would give it a try...
