The dpx looks interesting but I read a review that complained of lock stick and warned about blade play developing from repetitive opening. Is the glass breaker carbide? Is there something similar with phosphor bronze washers?
Lock stick is a safety feature.
Head down to your local gas station and pick up a lifetime supply of Tac Force knives. Serrations, belt cutters, etc. All to your hearts content.
Not sure how well the slick handle on the Code 4 would perform in a stressful situation. Mine locks in pretty good but I don't serve or protect for a livingI will say, check out cold steel options with a cts-xhp blade. (Recon? Code4?)
Great steel, they have very aggresive serrations, plain old solid knives, and at right about half your budget for most options available
Actually a Flash suppressor on a home defense or any rifle is almost a requirement
I don’t want to be fiddling with a separate glass breaker and cutter
Without getting into details I use the strap cutter and the carbide glass breaker quite a bit for alternative purposes
Hence my requirements
I appreciate the suggestions and helpful information
Please keep them coming
I’ll raise my budget to sub $200
What do you use the glass breaker for? I'm genuinely curious. The strap cutter has plenty of fairly obvious uses, but I'm at a loss for what I might use the glass breaker for other than breaking glass.
