If you would like to PM me and Will pay shipping both ways I will fix the knife for you.
Jim
Jim
What's wrong with it? Just looks like you need to switch to a fine grit and do some stropping to me.
ok I have figured out the problem, I am definately sharpening everything but the actual edge...should I increase or decrease my angle while sharpening? btw I pull the knife away from the edge instead of pushing against it. Should I decrease the angle and remove more material from behind the edge thus thinning it more?
What are you using as backing for the sandpaper?
To me... it looks like either your backing is too soft... or you are not being consistent with your angles.
Here is a hair splitting convex edge applied to an FFFBM... which is significantly thicker than the CGFBM.
Justabuyer took things further with his insane Hell Razor edge.
He does all his sharpening work by hand... but... I use an 8" buffing wheel for the final stages of sharpening.
I use sandpaper on top of a length of foam camping mat for the initial shaping at 180 grit.. then I remove the 180 finish with 600 grit... then the rest is done on the buffer.
Your knife is not ruined and it can all be fixed..... but... steepen the angle you are dragging the blade across the sandpaper... and check that your backing is not too soft... or you will continue to create what is an "over rounded" edge.
Hope that helps.![]()
