- Mar 19, 2007
Well - some 12 years ago I was hiking with my wife when I found an area that had some trees hacked up by some local kids trying to make a BMX track. There was about 4 Oak trees about 15 years old and stock straight. I fixed the ones I could but one had had it. So I cut it down, stripped the branches, and vowed that I would make good use of it some day.
Well that day came. It cured for over 8 years in my garage. I cut the split ends off and took off the bark (dear God that took time) with my SAK. In fact, I cleaned up the entire knife with the SAK. I drilled out the parts where there were branches, and drilled out the top for a FB 1605 Pyser Compass. I set that in two part epoxy and painted around to clean that portion up. I stained it with ebony stain (4 coats) and then put 5 coats of marine grade polyurethane varnish on it. I let that dry for six months or so.
I then wrapped the handle in over twenty feet of Mil Spec 550 cord (O.D.) and pulled the ends under to keep the wrap tight. I used it this weekend and took some (fairly poor) pics of it. It was excellent. A little heavy - but I am a big guy (6 - 5") so that was no problem for me. The compass is pretty accurate and given its original purpose should have no problem keeping up with the punishment it will get on the trail. The bottom was no worse for the wear when I was done hiking (about 20 miles in two days) and looked great.
Here are the pics:
Enjoy.
TF
Here are the pics:
Enjoy.
TF
