- Jun 11, 2006
Well i think my pid controlled forge has a problem. Or maybe it's just me. I did move the gas inlet to the burner and not the blower as i was smelling leaking gas. But last night i was doing some forging and started up the forge and set it to 2000 deg and let it warm up. I only have one speed controll connected right now so it pulses on and off. So after it warned up i started forging and after say like 5 min i noticed that the forge was pulsing on and off like every sec. I looked at the temp and it was smack on 2k and so i watched it for 5 min and it very only 1 deg in the plus or minus. I could not beleave it. The inside of the forge was an amazing even color. So i finished forging and then ground the knife and went to heat treat. I set it to 1525 at the same thing held it spot on what i set it to. I was shocked. The heat treat oven at work cant hold a temp that close. But my question is this. Is it bad that it is turning on and off every 1 to 2 sec. And how do i change the margin of its holding temp.
