Hello all,
I'm sure that there is a simple answer to this, but I haven't figured it out yet. I use the exact same drill bit to drill the pin holes through the tang and the handle slabs. The pin fits perfectly into the hole in the tang, but I have alot of difficulty getting the pin through the hole in the handle slab (sometimes I even lose my cool and try driving it through with a hammer and end up damaging the handle slab). I have tried removing a little material from the pin, but then it is a little loose in the tang hole. I have also used the drill bit to ream out the hole in the handle slab, but there must be a better way.
Any insight or suggestions would be appreciated.
Thanks
Thanks
