Hi guys, I am going to start making my first knife which is essentially a full tang bush knife about 4.5-5" long. It might see some batoning when in use. However I am wondering if I should have handle pins installed in it. There is one 8mm OD tube for lanyard installed at the end of the tang, but I have space for 2x 4mm/5mm pins in the handle. Personally I do not like the looks of pins and thinking of excluding them, relying on the epoxy to hold everything together.
Assuming I do a proper cleaning and surface prep, what is your opinion on using just epoxy and a single tube to hold the scales (cocobolo) in place? I have access to 3 ton epoxy, but will most likely use a 1 ton/sqr in. black epoxy if I decide to do any filing work.
PS I did some search here and google on this topic, none were specific or gave a conclusive answer. Thanks in advance!
