What do you guys think of screws instead of pins as fasteners on custom slipjoints?
In a recent thread on the custom forum, the utility of screws for the pivot and handles was touted. It allows for easy adjustment of the pivot when it gets loose and replacement of the scales if they crack. Pivot adjustment can be made by tightening a screw w/o having to pound down or pry open a pin which often results in having to refinish a bolster or possibly replace a bolster that's been engraved. A cracked scale can be replaced w/o any disassembly.
Personally I don't like the looks of screws on a slipjoint, but that's just prejudice. I do like the idea of a knife that is easy to repair since my customs are users. What are your experiences with pins and user knives, have you needed adjustments with the pivot that would have worked better with a screw?
I have experience with a loose pivot. One custom slipjoint got loose (two blade trapper, nickel silver and ATS34 blade and spring) and I sent it back to the maker. They jammed a small washer in and repinned it resulting in (a) slight gap in the liner/backspring due to the washer and (b) noticable pins when they were once hidden. However the knife is tight and strong. I asked for the repair to be domed pins for strength and easy adjustment, but this wasn't done. A pivot screw may not have helped because I think the real problem was a milled nickel silver liner that was too thin (or nickel silver wasn't strong enough) for hard use. That's why the washer was put in for the repair. Needless to say, even though the repair was free, I wasn't happy with the repair, because I was willing to pay for a better job (i.e. replace the liner.) Kind of made me a little shy of nickle silver vs. steel liners although I have had no problems with nickel silver liners in production knives.
Most if not all of the custom slipjoints posted here are pinned. Any of you Bose, Cover, Ruple, Davidson, etc. custom users had trouble with loose pivot pins or replacing pinned scales?
Are screws really better? Logically it seems they are.
Do the asthetics of pins trump the utility of screws?
Inquiring minds want to know
