Pinning slabs
I am going to be using some brass pins in stag slabs and was wondering how to get them down to the finished height without taking down the texture of the stag?
I leave as little as possible sticking above the surface of the stag. Then I grind the rest down CAREFULLY with a carbide burr in my air grinder. My air grinder is similar to a dremel tool, it just runs at a higher RPM. A dremel will work ok too. I only worry about that in the rough areas of the stag, I just grind the pins down on the belt grinder with stag material, on the smooth parts.
Neil
http://members.aol.com/blademakr/BlackwoodWP.html
