Pins are very pretty - if you're gonna use them, use lots. Just be careful you have a handle material that doesn't split easily, because they hold with friction and the holes should be drilled slightly undersized (in the scales - in the tang they can be a bit oversized to let the pins pass through easily). That gives a really tight fit and good hold, if the handle material can take the stress.
Rivets hold with that little lip on the stepped hole, so a tight fit is only important for looks, not hold. I love Corbies, personally - that big round metal spot looks like a giant pin, and is very secure. They can make a decent folder pivot, too, but are the priciest rivet. Loveless bolts are nice if you use two metals, like steel bolt and brass nuts, because they give a nice contrast. I don't care for them too much because there always seems to be a little gap where part of the threaded bolt is sanded off. Lukes haven't got much going for them, IMO - just like Corbies except you have to take care not to cut too deep or they look like Loveless bolts... kinda the worst of both worlds. Cutlery rivets are just for cheap stuff, and you have to be very careful not to take too much off of the very shallow heads.
In summary, I like Corbies for an attractive, secure fit, pins for beauty or to supplement the Corbies in tight spots, and Loveless bolts for the occaisional flavor.
-Drew Gleason
Little Bear Knives
