Pipemaster for soldering guards
I've tried using torches (mapp and propane) and the heat gun method (http://grizzly.com/products/Heat-Gun-1800-Watt/H0801) and I'm still not finding a reliable way to solder stainless to stainless.
The heat gun above didn't work for me, as it couldn't melt the solder (I use Staybrite) and it's easy to burn the flux using a torch (get's the job done, but requires more cleanup time).
I'm thinking about soldering irons now, how about this:
http://www.amazon.com/Antex-Electronics-P192V50-Pipemaster-Soldering/dp/B000CC3N5A
Has anyone tried using one of these or a high powered soldering iron? I would think that it would provide a cleaner source of heat. :confused:
*Another thing, if the heat gun soldering method worked for you, which heat gun do you use and how long does it take to heat up the guard to melt the solder?
Is the problem with the solder not melting or the solder not sticking where it's supposed to?
Part of what makes stainless 'stainless' is a layer of oxide that forms on the surface and it's difficult if not impossible to solder over that oxide layer, it must be fresh sanded and a good flux used.
The heat gun does work and it is cleaner, but it takes a bit longer than a torch. Not long ago I posted a thread about the way Mr. Loveless solders his guards. It's a high power soldering iron with a home made fixture on the end. You can see it on the video Loveless legend. The pipemaster is the closest thing to his set-up that I have seen. Looks like you could clamp that thing right on the guard, this would also help control the heat. Thinking about ordering one right now.
