Pit's BC Burner !
I took Maisy out today and decided to make one of my Camp torches, I don't know if you guys already make these or not but I first saw Ray Mears make something similar with tree resin and decided to try one with FatWood, that was a couple of years ago now, they work real well with FatWood....I call them my BC Burners !!!
You can see the mist as I approached the shore....
I just took my WSK, Vic Swiss Spirit and my PSK tody !
I used my WSK to chop out some FatWood and then also used it to split the green branch which was used for the torch stem.....
They burn for quite a long time and give off a suprising amount of heat for such a small amount of tinder......
Looks like fun, and great pics Pit!
edit: good question evolute
Interesting. Thank you.
Have you tried putting a big piece of fatwood vertically into the split, and lighting it from the top? Would that make for a smaller, longer lasting fire?
I have tried it that way but it seems to work better the way I have it, maybe it's due to the air space created between each one ?
Very great idea and tutorial! Have to try this out tomorrow.
could be, allows for better air flow the way you have it there. will have to try this out one of these days :)
I've never seen that type of torch .... good stuff !
How long did it burn ?
Thanks. Could you clarify what you mean by "works better"? What happened when you tried it that way?
I figured that the way you have it allows for better airflow, that's why I asked about the way I suggested. I suggested a way which I would guess restricts airflow, and thereby makes for a smaller, longer lasting fire.
Ah, I misread it, good point. Also, if it works, maybe one could carry it around without worrying as much about leaving a trail of burning chunks and embers.
In a breeze I found it blew out easier the other way and even when it burnt ok it did not seem to give as wide a spread of light....a little like comparing a regular flashlight bulb with an LED bulb...hope that makes sense. Try it out both ways and see if you find it to be the same.:thumbup:
As I had it the burn time was around 30 mins. Obviously the weather etc will affect this time one way or another !!!
very cool pit....:thumbup: i have made a few smaller versions of that.. they're alot of fun....
