Always go back to the grinder after heat treating.
Interested in how you are doing the D2. It needs to be around 1850f and a 1/2 hour soak to harden properly and is usually done in a foil envelope to prevent decarb at the higher temp. It also has 12% chrome which helps prevent the scale. But, if done in an envelope it will come out just as you put it in except for becoming a light gray color.Any idea why D2 doesn't produce the same irregularities as 1095?
- Paul Meske
