Pivot Lubrication
What is recommended for pivot lubrucation on folders?
Buy the most expensive lubricant you can get. Just follow the equation: the higher the price=the better for your knives.
Buy high-end dedicated lubricant from high-end dedicated knife stores. Nano oil does not have particles small enough. For knives the particles in the lubricant should be no larger as 1/2 an angstrom. Any larger and you are facing a disaster.
Please, don't use cheap and common motor oils or bearings greases. Only a drop will ruin nature and flowers in your garden and melt the north pole and south pole also and also ruin your knives and make them stuck and they will not open any more.
If your knives have ceramic ball bearings then you are f****d. You will need to order a very very special grease from Switzerland - so called 'Porzellankugelfett'. It's the best money can buy.
PS
Just read between the lines and use some basic logic and common sense and you'll be fine.
Quick release, Benchmade blue lube, Daiwa reel oil, graphite, mineral oil, crk grease, finish line grease. These are all great. There's alot more good choices too.
I would disassemble. But if you don't have any problems then just add a drop of lube on each side. Disassembly can be disastrous. So I can understand why you would not want too. But a fair amount of good knives are easy to maintain.
Avoid Nano oil. It's expensive label on mineral oil.
Avoid anything that will go rancid.
Haven't hear good things about Frog lube for the pivot, but its basically coconut oil and it's great corrosion inhibitor.
Some folks like wd40 but I'm not. When it evaporates it's just a gewey mineral oil.
Most people put too much lube of any type on. Less is better. should be very light oil along detent track for best action... And light oil in bearings, just enough to coat the bearings but not swim in it. Just enough to prevent corrosion.
Too much and then it collects dust and debris as well as creating friction. (do an experiment. Get a fidget spinner, clean the bearings with brake cleaner or acetone. See how long it spins. Then put a very very tiny pin drop of oil in the bearings and see it spin shorter).
Grease is great for knives, particularly washers. It's a barrier from debris, fluids etc and when applied the carrier in it evaporates and it dries making itself a Teflon washer in a way. When the blade rotates across it, there is very little friction. Nice and smooth. Only apply to blade side. You don't want the washer to rotate, so scale side should be dry. That goes for oil too on washers.
Both types, grease and oil work great with less lube than you would think. Action is heavily dependent on many factors but generally not by adding lots of oil. Action revolves more with the detent along the blade, lockbar tension and so on and so on. But most folks assume it's just the bearings in the pivot.
All knives are different and all owners are different. One knife may work the way you want it to depending on the oil or grease used. It may just depend on the environment or its use.
Lastly decide if you want food safe or not. Then read the label. If it's not food safe probably not a good idea to use a lot and then eat with that knife. I use both
When cleaning old lube or factory lube off, alcohol will not be strong enough to remove completely. This could cause issues. Also if your having gritty action and alcohol does not work... Acetone, Zippo Lighter fluid aka napatha and brake cleaner all work great. Use either of them with caution of course. Also don't use these on g10 or micarta as it could discolor. Just adding oil to remedy an issue isn't fixing the issue.
Recently been using quick release and its a great oil, very little is needed, as if you put too much on it will go all over the place. The half of drop can spread all over the place. I generally apply a drop on a qtip and spread it on the metal I want to apply it too. Add drops if necessary but angle the metal in the light and you can see it there. That's more than enough. It's not food safe. But the lubricity is crazy good. Puts Nano oil to shame (try and compare I dare you).
I'm really nerdy about my knives. Most people don't care.
Wd 40 is not gooey when the carrier evaporates. It just leaves a light mineral oil. I have a bottle That I sprayed WD 40 in 12 years ago. The mineral oil is still fluid.
I don't like to use oil to lubricate my knives.
By the way, I have Opinels and all my other serious folders have steel or ceramic ball bearings.
I use lithium-based grease - the one we use at work to lubricate all sorts of linear guides on our machines and toolings.
  • Like
Reactions: 353
I’ve given up on any oil or grease. I use Hornady One Shot dry lube. It drys to a slick micro thin super hard coating that lasts a long time and doesn’t attract gunk. My knives stay clean and operating smoothly way longer than with wet lube
Hit it liberally with some Ballistol- in the pivot, on the blade (and nail pull), and even the scales. Sit 10 minutes and wipe dry. Its easy.
Ballistol is so underrated as a pivot lube.
I use it on everything except for when I take down a sebenza, then I use the CRK grease.
Did A-B test with KPL regular lube, not the thin one. Ballistol was waaay better, both lasted much much longer and had better action feeling in the pivot.
It's food safe as well and dirt cheap.
Maybe not, but it is not a great lubricant. More of a cleaning aid.
Tried to run a OTF on just WD-40, didn't take long before it misfired. One quick spray of ballistol and it lasted many times longer.
Never tried that but sounds good.
But I guess u have to take down the knife to get it in there everytime?
Yes.
But this grease is sticky and resistant to high temperatures. I apply a very thin layer with small brush and the grease sticks to balls, pivot and liners and stays there.
On the other hand, if using oil knife also needs to be dissasembled once in a while for cleaning.
Whenever I take a knife apart for cleaning this grease is stil there where it suppose to be.
I must say I don't clean my knives very often.
Any oil will work. The only difference I've seen is the weight/thickness/viscosity of the oil. Thicker oil (or maybe grease) will make the action heavier, but smoother (according to most people). Thin oil leads to an easier/quicker action and the necessity to oil it more often.
I use Gun Butter because it was on the bench when I was cleaning a folder. Worked great! You aren't likely to make a "wrong" choice sir. Try what you have on hand. Worst case is that you don't like the way your action feels...then you'll clean it all out and try a different oil. All this is part of the fun of having folders. My only suggestion is to get a needle oiler. Much easier.
Ballistol and WD 40 both contain mineral oil as the lubricant.
WD40 is a water displacer though, it does not lube. WD40 basically removes all the lube (with all the dirt and what have you). Great for crusty and caked machine type stuff, but not food safe. So I would not recommend it for your pocket knife. Ballistol is food safe though, and it also lubes and acts like a creeping / penetrating oil; Ballistol Universal Oil also great for cleaning by the way.
Many people seem to think WD40 lubes, but it doesn't. WD40 evaporates and leaves a protective layer which is not food safe. The WD stands for water displacement by the way. If you clean something with WD40 make sure you lube it afterwards, if it's something that should be lubed that is. Ballistol doesn't really evaporate. I only use Ballistol Universal Oil on my knives. Great universal oil for many things, also protects from corrosion and also great to treat wood and what have you.
Best to read up on the producers information about what their product does though, like what it is good for and what it is not good for.
Edit:
Well, as it happens I read up in the WD40 website that it does lube (in the FAQ), the Multi-Use WD-40 that is. It does not say lubrication on the can though. 🤔 Weird. It's mainly a degreaser afaik and great for loosening caked machine parts.
Read up on WD40 some more and it only lubes a little bit, in contrast to Ballistol. I like WD40 for "outside" like in the workshop / garage, but mostly for cleaning caked stuff. For lubing, treating wood and such I prefer Ballistol.
I use 100% Synthetic for my knives and gun's High Temp and never dissipates...
Ballistic is my answer for everything from blades and guns to chapped lips and chaffed ass...😉!!!!!!!
Their website has a lot of cool info about the history of it.......Damn cool....
  • Like
Reactions: 353
I use the same gun oil on my knives as I do my firearms. I currently am using some oil from Hoppes. It seems to do a good job and I do not have any complaints with its performance.
