- Aug 7, 2013
Hey all!
Getting a bunch of friction folding blades cut out with a waterjet, and i have a few questions on pivots.
First up: My design has a 0.2400 pivot hole for the waterjet guys and then i can ream it to 0.2500. Do I ream it before or after I HT it? I am using AEB-L so i dont think scale will be a problem but i have no idea.
Secondly: These are the pivots im going to use http://www.alphaknifesupply.com/hardware.htm , (.250" Stainless Pivot), now it says the head of the larger end is 0.475 so i'd assume i would use a 0.5000 counter boar but that seems a little crazy...Will i get a clean cut if i use a huge boar like that? I plan on doing custom filework and pivot modification, so should i just grind the head to size?
Third: I am planning on using a 0.1250 stop pin, should i go with the .125" Stainless Pivot from alphaknifesupply as well? Looks like it will work and that pivot setup is what has been recommended by alot of people. My other option is a pressure fit stop pin(?) which is simply a piece of rod which is filed to size before pressing it into two half holes (not drilled all the way through both sides of the scales).
Fourth: Phosphor bronze washers? I was planning on using them because i hear they are self lubricating but if anyone has a better type id love to hear it.
Last question: Not related to pivots, but i am thinking of doing my own sculpted pocket clips out of titanium....Any drawbacks? Is it worth it to simply buy premade clips? I also dont like sheet metal pocket clips really, I like the look and feel of sculpted alot more.
Thanks in advance and I am hoping some other noob sees this and gets some help too.
