How does the locking system in the P'Kal compare to other popular lock systems, ie benchmade axis, linerlocks, etc.?
I like the way the knife looks, and would like to order, but want to see what you all think about that lock first.
Thanks
An advantage the caged ball lock on the P'kal has over the Axis lock is the spring system. The Axis lock uses a pair of small diameter omega springs to wedge a steel bar between the tang of the blade and holes in the liners. The ball lock uses a coil spring to wedge a steel ball between the blade tang and the steel backspacer. In absolute terms, I believe that the ball lock is stronger. In relative terms, either lock is probably stronger than you could break without a cheater bar, but I have read reports of Axis omega springs breaking and I have heard no such reports on the much heavier coil springs in the ball locks failing.
The ball locks use two coil springs, one inside of the other.
sal
As for liner-lock failures, I suspect we hear about so many failures not simply because there are so many liner lock knives in use, but because there are so many poorly made liner locks in use. Being easy to crank out is what makes it popular, not being a good lock. A properly engineered and executed liner lock is great, but it is as expensive to do right as any other good lock. A wild guess based on personal observation would put great liner locks as less than ten percent of all the liner locks on the market today. In other words, there are a lot of crap knives out there, and a lot of them are liner locks. That has a big effect on the failure rate.
