PL Knives: Vixen
Feedback: +13 / =0 / -0
$295 - Vixen:
Dual grind Scandi with flat ground tip. Grade A Ironwood bolster with brown burlap handle and resin/copper mesh divider, black / white / black triple G10 liner. Loveless bolts and brass tube
Includes JRE sheath
4 3/8 blade | 8 7/8" overall | 1/8" 80CrV2 | 4.5/5 handle thickness
Kydex and hand made leather sheath options are also available.
I began making PL knives in 2016. I've done leather work for over 20. I added kydex to my repertoire in the last 3 years. The heat treat on all of my carbon steel knives is done by me in a thermostatically controlled Evenheat knifemaking kiln. Each blade goes through a 3 stage normalization process, followed by heating to austenitic temperature and quench in Parks 50 oil. Then it goes through a 2 stage tempering process. Hardness is 61-62 hrc. Scales are glued with West Systems G-flex epoxy. My aim is to produce heirloom quality tools with excellent craftsmanship that will provide a lifetime of enjoyment and service.
You can see other examples of my work on Instagram.com/plknives or check out MY WEBSITE
WOW! That is ART my friend! Absolutely beautiful. Every attention to detail was on point with that beautifully crafted knife! The dual grind Scandi is excellent! Plus it looks like it is puppy dog approved!
Wow! Absolutely gorgeous knife!!! The dual grind! The dual liners! Just WOW!
Edit. I just realized it's triple liners 😯😲. That is a phenomenal knife!
