My point is that, asymetric blades will generally come off the plates with about .005-.010" of warpage. The stresses set up in the steel during quench produce this warp, and you will see it when you flatten the unground side of the knife-Generally the center section of the knife is a little higher than the ends. Not much, but it's there.
I have frozen my plates, too. Doesn't seem to make a substantial difference in the final result, but, it is useful to cool warm plates down before re-use. Plus, your plates are on the thin side, so, what could it hurt?
Remember, the quench rate with plates is much faster than what is required, even when the plates are at RT.
I hope you aren't heat treating with a 40 grit finish. 220 grit is recommended to reduce the the effect of stress risers from coarse scratches.
