- Oct 30, 2002
I've searched and found a few older and disagreeing threads, but I was wondering what the current consensus is on this.
I re-profiled a blade today from one I had accidentally fumbled onto its tip (prior to heat treat). I ground it down into a smaller EDC today, and while I was at it, I thought I'd try my first tapered tang. That went well and fast thanks to the Blaze belts I was using. However, now I'm starting to think about my heat treatment.
The blade is CPM154. It's fairly small (OAL of around 7") and was ground from 5/32 stock. Again, the tang is tapered, and there is a distal taper to the blade as well (though not as obvious as usual on this blade). I usually plate quench in foil between 1" aluminum. Is this still feasible with the tapered tang? Would a fan blowing air over and between the plates help at all?
So the primary question is will plate quenching still let me achieve what I need to from the heat treatment? Is there another option that would be more ideal? I'm also going to be doing a cryo in LN for the first time on this one (thanks to JM for the great deal on a dewar).
What do you think?
--nathan
What do you think?
--nathan
