OK, here is the HT regime for CPM-154 and most stainless steels.
Pre-heat the oven to 1400F and place foil packets in oven. ( You can place them in at 1200F if you want and let them warm up to 1400 with the oven).
Hold at 1400F for 10-15 minutes to equalize.
Ramp at 9999 ( full rate) to 1950F ( between 1900 and 2000F is the normal HT range for stainless).
Soak for 30-45 minutes.
Remove one packet at a time and place in quench plates. ( close oven door immediately after removing).
After 60 seconds, remove next packet and place in plates ( removing current packet).
If plates heat up above 200F, cool off with running water to ambient and continue pressing packets until all are done. There is no rush, as the extra oven time does the waiting blades no harm.
When all blades have been plate quenched, cut open packets and remove blades. CAUTION - the foil is hardened and can cut you bad!
Mix a gallon of denatured alcohol ( home depot paint dept.) and 5# of crushed up dry ice in a metal pan that is big enough to place the blades in. It will smoke and bubble, that is OK.
Place all blades in the pan one at a time and let them sit there for 30 minutes to an hour...or until the dry ice is all evaporated.
Remove and wash off the blades.
Temper at 400F for an hour, rinse in water to cool off, and temper blades a second hour. Rinse off to cool again and the HT is done.
This should give you a blade between Rc 60 and 62. To have a little tougher and easier to sharpen blade for rough use, temper at 450F for a hardness or 59-60.
You can do the sub-zero treatment between the tempers, but it does the most good immediately after the blades reach room temp from the plates.
Let the alcohol sit in the pan and warm up to room temp. Then pour back into the can and label HT on it. It can be used over and over again for sub-zero treatments. Leave the cap loose for a day, because it is slightly carbonated. Shake the can a bit and tighten the cap the next morning.
Cryo is done at -300F or lower, sub-zero is done at -95F. A dry ice slurry reaches about -100F.
Buy the dry ice at your local large grocery store or other supplier while the blades are in the oven or just before you start the HT. Place it in a cooler, and it will last for many hours. Once crushed into chunks and put in the alcohol, it lasts about an hour or so. Acetone will work as well, but the alcohol is safer and cheaper.
The larger the quench plates, the better they work on multiple blade batches. 4X2X16" is a minimum size.
