- Oct 4, 2017
Hey guys. Maybe I just want to feel like you brilliant guys building machines but I have been thinking about a platen idea that would have less friction (less heat) and only one problem I can think of now.
I will try to explain this as clearly as possible.
So, you know the slightly supported attachments for slack belt that uses a rubber belt over 3 wheels but not the drive wheel? Think of that as the wheel set up for this.
Now what if you used a fine linked chain. (the best example I can think of is similar to the chain for wrist watches) The chain would be 2 inches wide (well a tad less) and would drive around those three wheels like on the slack belt attachment.
This chain would be able to fold outward but not inward. This would allow the chain to move around the wheels but act like a solid flat platen. The chain would be overlapping links that lay flat against each other when inward pressure is applied. The friction and heat of the belt running against the unmoving platen would be eliminated.
I am not sure if you would want the chain driven or simply moved by the sanding belt.
The problem I see with this is the noise and vibration of a quickly moving chain. I am not sure what levels of precision can be achieved with a chain or what levels would be required.
What do you think? If you think it could work, what would you add or change?
Sorry again but my computer won't let me access imgur so here's a link to my example page.
https://www.barefootblades.com/Bladeforums-example.html
Stay sharp,
Ian
Stay sharp,
Ian
