Prepare for Heat Treat:
1. Profile
2. Drill
3. Mark scribe lines as well as height line
4. Attach File Guide
5. Grind 45 degree angles on edge to scribe lines
6. Grind from Scribe line to height line
7. Double check thickness of edge (.020" to .040")
8. Hand sand to 220+
9. Soften all edges with 400 grit
Normalize:
10a. Heat oven to 1550 (843c), insert blade, come back to heat and hold for 5 minutes. Remove blade and air cool
10b. Heat oven to 1450 (788c), insert blade, come back to heat and hold 5 min. Remove blade and air cool
10c. Heat oven to 1350 (733c), insert blade, come back to heat and hold 5 min. Remove blade and air cool
Clay Coat:
11a. Clean with Windex and apply thin coat of Satanite
11b. Apply a thick layer of clay on top 1/3 of blade and spine. Clay should be as thick as the blade
11c. Allow to dry
Hardening:
12a. Heat kitchen oven to 400
12b. Heat Parks 50 to 120
12b. Heat oven to 1450 (790c), insert blade, come back to heat and hold for 7 minutes
12c. Quickly quench in Parks 50, edge down
12d. Count to five seconds and remove blade. Count to five seconds and insert blade until cool
12e. Remove oil while quickly taking blade to heated temper oven
Tempering:
13a. Temper in 400 degree oven for two hours. Cool to room temp
13b. Remove clay and put blade in straightening jig
13c. Temper in 400 degree oven for two hours. Cool to room temp
Test Blade and raise tempering temp if need be
Thanks, Jason
1. Profile
2. Drill
Normalize:
Clay Coat:
11c. Allow to dry
Hardening:
Tempering:
Thanks, Jason
