daizee
- Dec 30, 2009
All this.
thin, shallow grinds are difficult. And in fact, FFG will be even shallower. Thin material moves as you grind it.
I grind with a work rest and push stick. Very "close to the machine", lots of feel. But also the blade doesn't get grabbed and pushed around as much. HOWEVER: there is risk to grinding very THIN blades with a work rest as it can get sucked through the gap between the rest and the belt.
So far my only use of a jig is for grinding harpoon profiles where the 'poon causes issues dragging across the work rest. ('poon could be ground in AFTER bevels too to skip the jig - if jigging isn't desireable for some reason)
