Thanks! Still learning my way around. This is helpful.
I think anyone new to sharpening should get some inexpensive knives of good steel. Then you can practice without being nervous. I was a jeweler for over 35yrs. Many times a practice on samples before doing the job. When you are confident and relaxed you do a better job. Plus this is something we do for fun....Maybe you try another technique? There are several ways to sharpen a knife freehand. Some prefer a wiping movement, that means you move your blade with the edge ahead from heel to tip over the stone. Or you could try a circular movement, make small circles and work your way from heel to tip. Recently I got hands on an old Bushcraft manual. The knife sharpening advice was to hold the blade at a slight angle on the stone and draw the blade toward you (with the handle towards and the tip away from you). I am sure that there are other techniques.
When I started to sharpen freehand I had problems to keep the angle steady. A circular movement instead of a wiping one helped me. That was easier to feel and keep the right angle. Maybe you try something different and see what happens.
Another mistake was that I used too much pressure. Just a slight pressure (more or less the weight of the knife) helped to get a much finer, sharper edge.
And the stone shouldn't be too fine because you need to set an edge first before you polish it.
And you need to spend the same number of strokes on each side of your knife. But I am sure that you know all that already.
I mention those thinks because that were the reasons I weren't successful at the beginning.
