- Aug 17, 2012
Hi All,
I have just taken deliver on my new KMG Chassis and I have lined up a 3hp motor and VFD and I am trying to determine the best way to set it up.
Just for a bit of background, up until now I have only been working with a cheap 1x42 frame and a 1/2 HP motor and I have zero experience dealing with speed control etc.
I have been trying to read up on RPM vs drive wheel size etc as well as desirable surface speed and I think I am overwhelmed and starting to get cross-eyed over the calculations and was hoping you experienced folks could maybe help simplify things a bit for me.
What is the range of surface speeds that most often will be worked with? If it matters I am building smaller to average sized knives and will not be looking to make swords or the like and will work with a range of materials from 1084 to the stainless steels. The reason I am asking is the motor is a 3550 RPM motor and the drive wheel on the KMG is a 4" wheel and I am trying to decide if I should be using a 1 to 1 pulley to the drive shaft and if so, what diameter of pulley to best control the speed of the motor within the ideal ranges.
Am I overthinking this? Does the fact I am using VFD negate this concern all together? I just keep thinking that 3550 to a 4 inch wheel is ridiculously fast and it might make sense to lower the speed with the pulley even before considering the VFD...
Thanks in advance for any advice!
