How do those things work. Do they reduce voltage or current into your motor? I guess the current is going to be determined by the motor & the load on it so those things work by altering voltage?
I guess if those things lower voltage they will increase resistance & heat in the windings till the motor overheats???
Did a little research. A simple single phase induction motor, I believe, basically spins at the input frequency (60hz). I believe things like this modify the frequency to slow down the motor. I think they are called adjustable frequency convertors. This can be bad on the motors b/c w/ AC power, as frequency decreases, impedance increases (basically resistance) which will make your motor run hotter. Motors that are designed to work w/ these devices are generally built much heavier & can take this better.
Maybe one these would be alright as long as you didn't slow it too much & you only used it w/ very light load, like when polishing an edge.
