- Jun 2, 2010
I believe it to be post-WWII. Any information you could provide would be much appreciated.
Specs:
Weight: 3.11 lbs, 1.4 kg
Length: 40, 101.6cm
Katana Dimensions
Overall Length: 39 ¾, 100.9 cm (not including Scabbard)
Blade Length: 26 ¾, 67.9cm (Blade only from tip to blade collar)
Blade Colllar to Back of Guard: 1 ¾, 4.4cm
Handle, Tsuka Length: 11 ¼, 28.5cm (From guard to Pommel)
Weight: 2.1 lbs, 1.2 kg
Scabbard Dimensions
Weight: 1.1 lbs, .5 kg
Length: 28 ½, 72.3 cm
Tang
7 ¾, 19.6cm
One Peg Hole
Makers Mark, on Right Side, (Unknown, unable to translate)
File Marks on Tang only
Sword Guard
Round, Metal
3 ½, 8.8cm across
Detailed with 2 Dragons
Overall:
The dowel from the handle:
Blade metal:
Handle:
Guard:
Markings:
Scabbard:
Thank you!
Specs:
Length: 40, 101.6cm
Katana Dimensions
Scabbard Dimensions
Tang
7 ¾, 19.6cm
One Peg Hole
Sword Guard
Round, Metal
3 ½, 8.8cm across
Overall:
Blade metal:
Handle:
Guard:
Markings:
Scabbard:
Thank you!
