- Mar 19, 2010
My PM2 has developed a bit of bladeplay. I tried to tighten the pivot, but it won't move. How can I get it to turn? And when I turn it would I do both sides of the pivot or just one?
Lateral play should be adjusted with the pivot screws, not the stop pin screws. Use a pair of *properly fitting* Torx drivers, one on each side. Be careful - if you strip the screws you may wind up sending the knife in to Spyderco for non-warranty repair. If they really won't move, try warming them (very carefully, just warm NOT hot) with the tip of a soldering iron to soften the thread locker.
I developed blade play in my favorite knife, a pm2 with cts 20 cp steel. After carefully tightening the pivot screws as much as I could, the lateral play remained and I could not get the screws to loosen , even with heat. I returned the knife to Spyderco for correction. I received a call from the lady doing the repair telling me that she had replaced the screws and was able to tighten the blade by tightening the pivot screws and the stop pin screws. Even with these meaqsures, she said the blade wasn t completely tight, but that was the best that could be done. On receiving the knife it was tight by my standards,but it loosened again fairly quickly. I loosened the two pivot screws and the stop pin screws and retightened all 4 screws after applying loctite to the pivot screws. My blade now locks up completely tight and is smooth. It has remained that way. I have other pm2 s that have been successfully adjusted with loosening and tightening all four screws. I believe all 4 screws must be used in adjusting this particular model.
I tried adjusting all of the screws, but they won't turn. Is there a way to make them turn? Do I have to melt the loctite?
Some PM2s will not respond to pivot screw tightening due to manufacturing tolerances and the design of the step pivot in the PM2. There are a small number of these knives that have oversized (too wide) dimensions that prevent tightening the pivot screws enough to eliminate lateral play.
I've posted on this many times, but lateral play should be adjusted with the pivot screws. After those screws have been set correctly, blade play should be adjusted, if needed, with the stop pin screws. Loctite is a good idea on the pivot screws and often required on the stop pin screws - but use only blue Loctite.
Hey, thanks for this info. I have a new green pm2 now that is driving me nuts. It has a little side to side play ( pretty minor) that I can not eliminate! I am able to get my s30v pm set just right where the blade falls open but there is no play. This new one won't do it. Either there is play or I tighten it down so tight that the blade won't move freely...and even then there is a tiny bit of play compared to none on my old pm2. Sucks because I really love this steel but the action and lockup is smoother and tighter on my old knife! I am hoping someone has a "magic fix" for this, but I may have to practice acceptance! And that is hard!! Hehe
I feel you
My Green Para 2 has a little side to side and has even developed slight movement up/down. I still love the knife but my Digicam Para 2 is perfect.
I know! I would be much happier if the s30v was the one with the play. I'm actually thinking about switching the blades and having a cts204p with digi camo.![]()
