Unless you have a shop grade heat gun, a hair dryer ain't gonna do much of anything to G10. That I can assure you.
Well, I happen to own about 20+ Para and Para2s. I've inspected each one as it was purchased over the last few years and I can say definitively that none of e examples I have show any blade play. I know that some folks have reported what is infact play, however in some cases it is not accurate. In addition, all of my Para2 knives have the pivots as tight as they were from the factory (which is all the way tight), and the blade open with little to no resistence. I have to conclude that Spyderco meant to design these knives in such a way as to have the pivot tightened as much as possible without the need for any adjustment; however, it would appear by some accounts that the stepped pivot is not exactly within spec. Some foks have filed burrs off and other things that weren't quite flush. Others have mentioned that the PB washers were not quite thick or were in fact too thick. Hard to say in some cases, I can only speak to what I've seen in my own pieces.
