Also, you need to google up a lot of cuss words and memorize them.........
you'll want them ready for when you break that first 1-72 tap !!!!
Seriously, if you have never used a tap, starting with #2 to #0 taps is going to be a brutal beginning.
I would suggest learning on #6 taps in 1/8" stainless sheet. After mastering it, move on to #4, then #2 , and finally #1. Practice on the sheet until you have it down before going to a bolster on one of your knives.
Tapping is not too difficult if everything stays absolutely straight. If the tap is deflected even a tiny bit by any side pressure, if will break off in the hole. That can be a big problem in some cases. Perfectly straight and properly sized holes are critical.
You will break a lot of taps learning.
If you are going to do this as part of knife work, and the cost is justified, getting a tapping jig (tapmatic and others) is a nerve saving expenditure. If you are only going to do it once in a blue moon, getting a gun shop, machinist, or knife maker to do the job (you provide the disassembled bolster, screws, and clip) will be much smarter. You will have to disassemble the knife, BTW to add a clip.
Stacy
