Thanks for the comments, all!
Dozier, he's actually a very nice cat. Very relaxed and easy going. He's also pretty smart. He knows his name, and comes when I call.
Ok, back to work. I made a course change over the weekend, which I'll explain in a few posts. First, the blade.
I finished with the grinder at about 600 grit:
then handsanded with 600 grit paper:
then into the ferric chloride for 10 minutes:
Then I sand the oxides off with 800 grit paper, then etch for 10 minutes, then sand with 1000 grit, then etch 10 more minutes, then polish with 12000 grit paper. Some sand to 1000 grit or more before etching the first time, but I've found that doing it this way goes much faster, and uses a lot less paper, as the acid acts as a chemical abrasive. I literally use one small piece of each grit above 600, and just a few seconds of time, for the same result.
After I'm happy with the blade, the sheath and handle are sanded square and flat at the open ends:
