Pocket Woodcrafter and Compact Skinner
bikerector
Feedback: +163 / =0 / -0
The pocket woodcrafter is a nice little knife for woodworking and fire starting. It’s a compact bushcraft knife with a short blade that is capable because it has a full-length grip and neutral handle style that allows for many grips styles. The elevated tip lengthens the belly while acting as a perch for your forefinger or thumb, giving increased control of the tip and belly.
This knife is perfect for the outdoorsman who wants a lightweight and compact knife for starting fires, working wood, and some food prep while still being a good option for EDC.
Designed by me and made by JK Handmade Knives.
The price is $130 shipped for the knife and add $15 for a leather pocket sheath. There are 4 knives and 1 pocket sheath currently available.
Here are the rough specs
Blade Steel: O1 Tool Steel
Hardness: 58-59 RC
Heat Treated by: JK Handmade Knives
Blade Grind: Scandivex
Blade Thickness: 3/32”
Blade Length: 2 1/2”
Blade Width: 0.69”
Handle Material: Black Micarta
Handle Length: 3 7/8”
Handle Thickness: 0.59” at thickest point
Handle Width: 0.65” at center
Overall Length: 6 5/8”
Weight: 2.3 oz
These are individually handmade so slight variations between knives can be present. Different handle options are available by special order for $15 extra for most handle materials.
The Sick Nasty: takes its inspiration from the spey blade pattern of traditional folders, modified to have more edge in order to function as a perfect modern everyday fixed blade carry option. The curve near the heel of the blade gives it that great slicing action in both forward and backward movements.
As a knife designer, I’ve tried to pack as much belly into The Sick Nasty as I could. As a result of working with JK Knives, like a traditional spey blade pattern, it is an exceptional slicer with a strong tip that is useful but not so fine and stabby that it easily penetrates things you don't want to pierce. The Sick Nasty's palm filling handle is made from roughed micarta that provides an optimal amount of purchase and grip.
It's an optimal small game cleaning knife, but much more substantial in the hand as compared to a caping blade and certainly isn't limited to that task alone. It really surprises on the kitchen cutting board, despite its short blade length and will serve well as a compact camp kitchen knife for the weight-conscious outdoorsman.
The price is $130 shipped for the knife and add $15 for a leather pocket sheath. There are 3 knives and 2 pocket sheaths currently available.
Here are the Specs
Blade: 3/32" thick O1 tool steel
Blade Length: 2 5/8" blade length
Handle Length: 4" handle length
Handle materials: Black micarta with aluminum pins, hollow pin at the rear
Weight without sheath: 2.6 oz
Customer picture with the try-before-you-buy knife
