- Jun 17, 2001
Thanks Raymond!
Your welcome. Just be careful.
Almost got this thing done. Probably get it epoxied tomorrow!
Thanks Raymond!
Ahh I liked the guard a little bit longer! That's a knife size guardAwesome looking still.
I got a question for you Ray.... Since you do a lot of knives with the forge-finish on them, how do you deal with the decarb, or is that even a consideration? It's just that I hear so many guys saying "oh you have to leave so and so much thickness to grind after heat treat"...But if you can do a forge finish knife and it still cuts great, perhaps this whole decarb thing is not such a big deal anyways? What do you think? I for one don't like doing a lot of grinding after heat treat...if at all.
I watched Tim Lively's video where he soaked the blade after in vinegar. I thought the soak just removed the scale, but I don't really know... Are "scale" and "decarb" just different names for the same thing? If that is the case, then yes, I always remove the scale prior to tempering anyways. Sorry for all the questions. Two very fine looking swords you got there! I love the work you did on the handles/hilts.
The decarb is the black stuff that sticks. Most the scale can be knocked off with a wire brush. The vinegar works quite well on most decarb. Now with L-6 the decarb has got nickle carbides and its much harder to remove. Sand blasting works best for that.
Justin, I try to keep things simple. When I build a knife I just try to keep things in a visual balance.
