Originally posted by Cliff Stamp
Stropping is much more sensitive to technique than using crock sticks. I can get similar sharpness with both techniques, but I have to pay a lot of attention to stropping, v-rods you can do rather mindlessly.
That sounds about right - and I'd be the first to admit I am by no means any expert in this -
However because of this apparent rolling away the sharp edge effect that I thnk I perceive - I am pretty careful about stropping - or at least tried to learn a more consistent way.
For example I never strop so that the blade edge becomes close to anywhere near right angles (90deg to the strop).
In fact I was so "paranoid" about this that at one time I found that I was only really polishing the secondary bevel and not the final edge itself.
By trial and error I found that if I can see and feel the rough side's nap rebounding that's about right - (if the nap is not rebounding then I am not stropping the edge) - then I am careful not to cause the blade to go beyond this angle for fear of rolling away/blunting the edge.
I do this by sound on the smooth side - when the cutting final edge is contact with the strop there is a sort of scraping sound - a slight lessening of that angle and the sound goes away - more then the there's a danger that the blade's edge may actually start to cut/marr the leather.
So although I do not consider myself an expert - I think I am being pretty careful and consistent about my stropping.
I can examine the edge with a 30x illuminated microscope, so I can see my progress - for example I got rid of the flats from my ATS-34 small Sebenza from cutting that dirty sisal rope from the footmat - by using the crock-sticks (fine white) then stropped to polish the final edge.
(actually I stropped first to see if I could get rid of the flats - it did not, and I merely polished away the scratches on the secondary bevel face...... I had to use the crock-sticks to get rid of the flats)
Originally posted by Jeff Clark
Some alloys seem to suffer when stropped very much with a light abrasive like green buffing compound. For me this seems to happen with high alloy stainless. I think that ductile components of the alloy are getting moved into nooks and crannies between hard carbides. Using white ceramic rods seems to undo the problem. I find that I get a better edge on these alloys when I finish using ceramic rods.
Now this makes some sense to me - as most of my knives are stainless steel - with the most used/sharpened being a Victorinox SAK - like Jeff I found that if I carefully hone the knife with the last step being the fine white crock-sticks (V-hone) - then if I strop I seem to lose some sharpness - eg: hair shaving - but a few (like only 3 each side) light strokes on the fine white crock-sticks will make the hairs jump off........
Perhaps my stropping technique is just not good enough -
but I cannot figure out how to be better at it - so far ........
So any advice will be gratefully accepted.
