Originally posted by Cliff Stamp
If you lift it too much, the leather can indent too heavily around the edge and possible abrade across it which would reduce sharpness.
<snip>You can mark the edge a little to see where you are hitting it, same as you would with a stone.
Thank you very much for being so helpful Cliff.
Yes, I kind of knew about too much lift raking or abrading the edge - however it is too easy a thing to do when doing free-hand stropping on a hanging strip type leather strop - I don't think I do it consistently enough to be sure this has been my fault/problem - but I'm sure there are times when lifting the blade off the strop to turn it over I may well have raked the edge.
I am (obviously) now paying more attention to make sure that I lift the blade off cleaning without turning the edge toward the strop.
I think the reason why the face stropping worked with the Opinel #8 was purely because the blade is Convex ground and I was following the convex face contour to primarily polish the face - and since the Opinels have zero continuous edge bevels I basically was stropping the edge too.
Even on Opinels that I had touched up with crock-sticks the "discontinuity" between the slight final edge "bevel" and the original convex face is so slight that the "face" stropping basically gets the "new" edge - does that make sense?
Whereas on a blade with a separate and distinct edge bevel I thought one should hold the blade so that the bevel is flat against the strop.
I just read a hint in using a leather "hone" for finding the correct angle -
lay the blade flat on the leather - and gradually lift the spine while carefully/lightly pushing forward, when the blade is just biting is the correct angle -
one then pulls from edge toward the spine at this angle to strop.
Good hint about marking the blade edge to make sure one is stropping the actual edge -
although is there a way to show if one's angle is too much and one is blunting the edge? -
Which brings us back full circle - on whether edges left at the final stone hone are sharper or not compared to one that has been stropped/polished -
the problem here might be incorrect (or at least inconsistent) stropping?
