If you have access to iron chloride, you can make the water solution for chemical conditioning of copper-tin bonded stones. Iron chloride will "burn" top thin layer of metal and expose new abrasive particles. I have read that it's a better way of conditioning metallic stones than physical refreshing. We plan to add iron chloride to our product matrix after tests.
What about the glue holding the stone to the blank will the iron chloride dissolve the glue.
Hahaha, well, now we knowLooks like it was a bad idea. Iron chloride dissolves aluminum, so the blank looks shitty after first use.
We will add Metallic Poltava Diamonds in Edge Pro format this summer. Estimated price between Venev and CBN.where are the metalic diamond stones in edge pro format sold? 1'' x 8'' would be awesome.
Metallic diamonds and Metallic CBNs have very similar flatness because the manufacturer follows the same quality standards for both lines.Gritomatic will the Metallic Poltava Diamonds have the same quality as the Metallic CBN in regards to flat aluminum base and pretty much flat out of the box without a necessity to lap. I've gotten a few of the bonded diamonds where the aluminum wobbles on a flat surface and the cutting side needs lapping. There's enough flexibility where it doesn't sharpen even. Really makes me not want to use the bonded diamond plates. On the other hand, the metallic CBN so far has been excellent and meets expectations, worth the extra money for the quality alone, flat aluminum and flat product side.
It can use dryWade, Did you use water on the stones are just use them dry?
