Portable Arctic Air Cooler is a freon free, three-speed controlled fan with USB powered design, it’s convenient to use it anywhere unlike other AC powered cooler. The latest evaporative cooling technology, draw in hot air and pass it through a wet filter, which then exits the other side as cool, refreshing air.
This portable air cooler can cool, humidify and purify the air around you. Easy to operate, simply fill with water, plug it into USB port or power bank and the three-speed fan will start blowing. Built-in water tank lasts up to 8 hours.
It also can be used as a soothing night light, sleek compact design fits nicely on your desk, bedroom. The built-in LED mood light can be set to any of its 7 color option, or set to color-cycle mode or turned off with the touch of a button.
Affordable, portable, and efficient alternative to an air cooler unit as well as an efficient replacement for a fan. This space-saving air cooler can fit nicely in work spaces, dorm rooms, offices and more. You can take it out for camping, travelling for its lightweight design.
Product Features:
● Easy Operation
It only requires everyday cold water and no Freon need. Simply add water into the tank, plug it into USB port or power bank and the three-speed fan will start blowing. You can even pour the ice which could make cooler wind in the tank, fragrance is also feasible. Add a drop of essential oil, smell pleasant! 300ml built-in water tank can be used for up to 8 hours in highest shift. Left button for adjusting three speeds, and the right button for setting smoothing light colors.
● Powerful Cooler and Humidification
Utilizing multilayer evaporative water filter, adopt the method of evaporation of water vapour to refrigerate, it can effectively turns hot dry air into cool moist air and refreshing air at the same time. Keeps you cool and skin moisture, more comfortable and healthier than staying in air-conditioned room all day long.
● 7 Colors LED Lights
The built-in LED mood light features with 7 colors, which can be set to any color option. You can choose one colour to help improve your sleep or you can set it for a soothing nightlight. It has two different modes: cycle color or turn off so the LED lights can also be changed automatically in 7 colors. Whatever day or night, brings you freshness air at any moment.
● Power via USB
Powered by USB cable to compatible with computers, laptops, portable chargers and other devices with USB output. It helps you save energy and use it conveniently anywhere, like office,home, kitchen,car and outdoor with a power bank. The power of the personal space air cooler is 10W, can work up to 4-5 hours supplied by a 5000mAh power bank.
● Adjustable Blade, 3 Set of Fan Speed
The wind outlet blade can be adjusted, move up and down 90 degree like air conditioner. The fan speed have 3 options - low speed, middle speed and high speed to fit your different need such as when you are sleeping, working or doing outside sports.
Refrigeration, humidification and purification 3-in-1 portable cooler fan built in evaporative water filter, makes the warm and dirty air be cool, clean and comfortable around your personal area. It is much cooler than desktop fan, more humid and energy efficient than air conditioner. Occupies smaller space, it will be your ideal partner in this summer.
Get it with the price of $34.55 at GearVita.com by using the coupon code "AIRCOOLER" when you checkout: https://gearvita.com/portable-coole...-space-cooler-easy-quick-way-conditioner.html
Product Features:
● Easy Operation
● Power via USB
