Before re-shaping the blade, check and see how much damage you did first. If the edge is fairly thin, do a simplified brass rod test. If it is a bit too thick for that, put a very quick and dirty 30° edge on with a 120 grit belt.
Mark an arrow on the blade with a sharpie where the spot is. Place the blade at 45° on a 1/4" brass rod. Press down firmly and pull the blade from ricasso to tip across the rod. Look at the edge and see if it has bent in the overheated spot. If it looks the same, try again on the other side with a bit more pressure. If it passes the test more or less OK, I would go ahead and finish it as is. If it bends too much in the damage area, grind back the blade a bit and re-do the bevels as needed.
