Phil705
Basic Member
- Aug 23, 2007
What the **** am I doing wrong?!! I recently finished the HT for four blades in 154CM, and I am still cleaning crud off the blades!
Here is what I did: Cleaned with acetone, washed with water. Dried. Dosed them with talc, added a piece of cedar, wrapped in heavy duty SS foil, pressed out the air as best I could, double crimped the edges with pliers. HT was 1950 degrees F, with 45 minute soak. Pretty sure my oven is accurate. Plate quenched with light pressure. I had no foil-welding, but the blades have a scale, almost a patina, that requires grinding to get off.
Is this normal? I have spent about 20-30 minutes per blade getting the crud off, really difficult near the plunge lines. Steel wool wouldn't touch it; hand sanding was a waste of time.
I would appreciate all ideas on preventing the build-up and/or getting the stuff off if it can't be prevented.
(I did put one post-HT blade in vinegar to see if that would help. Big mistake. The blade turned almost black, and I almost decided to leave it that way as it looked pretty good if you like the military tactical look. Had to grind it off with 500 grit.)
Phil705
Winthrop WA
Phil705
Winthrop WA
