Post pic of the MEANEST, SICKEST, BADDEST knife you've seen!!
As above.. but no fantasy knives please... cos we all know they are the obvious winners.. so let's look for the runners-up...:eek: :eek: :eek: :eek:
Meanest, sickest and baddest, but still workable, functional good edged cutting tool...:cool:
The Klingon ceremonial fixed blade designed by Duane Dieter of Close Quarters Defense, manufactured by MOD knives. AKA the Mark V.
From CQD.net
Like all CQD® knives, the Mark V has the largest hilt possible in order to protect the operator's hand from oncoming harm, whether it be in combat or utility use. When stabbing, the contrasting surfaces and expanded hilt work together to keep the operator's hand from overextending and sliding forward over the blade.
In wet or muddy conditions, the "center-point grip" can be used by sliding one finger between the Striker Hilt™ and the blade. This position allows the operator to retain the knife in even the most slippery conditions. Tactically, the center-point grip should be used when you have the advantage in the fight, or during utility use. If a situation calls for extended reach, two fingers may be inserted in this way. When additional reach is needed, the Mark V may be lashed to a shaft for emergency use as a spear or probe by combining the spear groove and the Striker Hilt™. One of the main reasons the Striker Hilt™ is on the Mark V is because I wanted a knife with a prying capability. The tip would break off of every knife I have ever used for this purpose. In developing this capability, CQD® found that this material, length, and appearance was necessary.
Another use of the Striker Hilt™ is to supply the operator with additional "fingers". When tightly gripping a large knife, or any weapon for that matter, in a combat situation, an operator loses the use of his fingers for other tasks. The limited penetrators on the Striker Hilt™ allow the operator to grab, twist, puncture, or hold numerous things without ever loosening the hand's grip on theknife.
The limited penetrators also provide additional options when utilizing the knife tactically. Usually, the only options available on a large knife are deep or draw-cutting techniques and blunt techniques using the pommel. However, by using CQD® prisoner control techniques, the limited penetrators may be used in a variety of ways to control any part of a subject without causing massive injury, blood loss, or trauma. For example, when severely cutting a subject is not warranted but forceful control is necessary, the penetrators may be used to pierce and trap the subject's arm, neck, etc. This allows for a much greater element of force control to be used.
The limited penetrators provide a greater aspect of safety and control in fighting. When actually attempting to cut a subject with the blade and the strike misses its mark, perhaps to the right or left, the penetrators may still catch a piece of the target. When penetrating a soft target with the blade, the Striker Hilt™ and limited penetrators supply a stop to prevent over-penetration of the blade into the target. Or, if at the last moment, the operator sees it is not necessary to cut the subject using the blade, by simply flaring the attack the limited penetrator allows the operator to reflexively control it to inflict a much lesser wound. In addition to piercing techniques, the outside of the limited penetrator, as well as the pommel are both capable of impact striking.
In conclusion, the Mark V, over any knife in the world, is the most force control-oriented. What is neat about its design is that it ended up looking so aggressive, but in fact, it has the greatest range of force control. No other knife has this type of impact control, limited penetrator control, side of the blade control, and to be able to move it reflexively as well.
It's sick, it's bad, but apparently not very mean.
BEHOLD the BADDEST, MEANEST, SICKEST BLADE EVER!!!!!
and now a little about it~
Bearing the namesake and call sign of legendary Navy SEAL Paul Basal, this knife is the new choice of operational warriors throughout the globe! Designed by Basal with the Dark Ops design chief, it features all the critical items for a Modern Spec-Ops knife. The Shadow offers an extended blade length for penetrating Comm-bloc frag vests with an accelerated spearpoint tip and sharpened foretip for maximum penetration. The top edge features a bone breaker and a radical, self-cleaning BlastRip™ saw for carving survival notches in spears and anchoring notches for detonation cord. A pat pend. BarbSnap™ cutter allows for rapid notching and snapping of interdiction wires in entry ops. An abbreviated top-hilt/bottle opener works with a new serrated palmstop, allowing for a reverse grip with an astonishing six linear inches of surface area! The Shadow features a corrosion resistant finish designed to take the saltwater immersion often involved in SEAL operations. The handle is made of a low-durometer, high tensile aramid composite that is impervious to everything from aviation fuel to Al Qaeda body fluids. The handle is thinner and wider for greater mechanical advantage with deep finger grooves orienting the blade axis of the knife in the hand and dramatically increasing effective grip surface. A prominent WhipLok™ finger notch provides an axis point for hacking as well as 200 degrees of grip area, ideal with wet hands or when using gloves. The handles are field replaceable to blend with woodland, desert or black camo schemes. Quartz impregnated inserts provide extreme circumstances grip enhancement and are replaceable should decontamination be required. The Basal Shadow utilizes the same CTV2 Blade Steel and CryoHardening techniques as the StratoFighter™ Folders! The hilts do not protrude forward effectively reducing the length of the blade. Hollow grinding lends to greater cutting and slashing effectiveness. Deep blood grooves keep the weight of the full .250 inch thick blade properly balanced in the hand. The black Titanium CarboNitride (TiCN) vacuum deposited finish is designed to shed the micro-fine airborne sand of Middle-Eastern deserts."
Oh yeah......Thats one BAD MFER!;) ;) ;):foot: :jerkit
i actually like most striders, so no knock on mick or dwayne intended. but this is one of a few knives i have seen i simply do not understand......
sick, bad, and looks very mean.
Hey Guys...
Lets not forget the REKET Hobbit and Pocket Hobbit...
ttyle
Eric
O/ST
Good God, that Dork Ops Basal Shadow beats the pants off the CQD Mark V. I mean, a fighting knife with a BOTTLE OPENER??? And on top of that it can never catch HIV from a terrorist!! Screw prying/hammering capability and nonlethal force control options, I gots to get me one of those, pronto!
P.S.
That Strider looks like it is meant to be a hatchet with a stabbing point and a thumb ramp plus concave secondary blade for whittling sticks. Or it's supposed to be a khukri with chunks bitten out of it.
This thread is funny but a little off topic as it is becoming a make fun of expensive mall ninja knives that take themselves to seriously.
The SF dagger is the ultimate bada$$ looking knife.
The hattori fighter is pretty as well.
mmm nice.. and I was wondering when the busses would be making their entrance.... is the last knife from Mineral Mountain??
how bout these? yea, theyre not the new 'space knives' that tops or mod are but, :jerkit:
these are pretty mean lol... i guess....
[/IMG]
I'm still trying to think of the scariest ever, but there's something so understated and deadly about a good japanese tanto...
I couldn't see the thread heading in any other direction, considering the title includes words like "SICKEST" and "BADDEST". If that doesn't scream mall ninja, I'm not sure what does.
... offers an extended blade length for penetrating Comm-bloc frag vests ... An abbreviated top-hilt/bottle opener works ...low-durometer, high tensile aramid composite that is impervious to everything from aviation fuel to Al Qaeda body fluids... 200 degrees of grip area...replaceable should decontamination be required...hilts do not protrude forward effectively reducing the length of the blade... Deep blood grooves ...designed to shed the micro-fine airborne sand of Middle-Eastern deserts."
Yeah, I think we have a winner right there.:rolleyes: :barf:
