- Oct 2, 1998
Thus you give up the spear?
I said "Call me Ishmael"...not Ahab.
P.S. (I'm impressed.)
The "Whale Folio" is rough.Don't be too impressed, I'm actually yet to finish that one. I really should, but every time I think about it, I'd almost rather go back through the "begats" in Genesis...
That’s a darned good look.
I knew he wasn’t just another pretty face!I said "Call me Ishmael"...not Ahab.
Does the Sebenza 25 have the same blade thickness and grind as the Inkosi?
Yeah, but there's something fishy about him.I knew he wasn’t just another pretty face!
Well done!Yeah, but there's something fishy about him.![]()
Stock thickness is the same. as for the Grind, The later runs of the 25 went to the same grind as the Inkosi would eventually ship with. The early 25 while considered hollow are damn near flat. You need to put a straight edge up to the blade to even see the hollow.Does the Sebenza 25 have the same blade thickness and grind as the Inkosi?
Interesting. It would be neat to see an Inkosi but with the same blade stock and grind as the Sebenza. I always wondered if thats what the 25 was.Stock thickness is the same. as for the Grind, The later runs of the 25 went to the same grind as the Inkosi would eventually ship with. The early 25 while considered hollow are damn near flat. You need to put a straight edge up to the blade to even see the hollow.
This of course makes the 25 a bit heavier with a bit of a forward on the balance in hand.
The knife feels a bit overbuilt which I am a fan of. View attachment 2312894
Wouldn't that just be a 31?Interesting. It would be neat to see an Inkosi but with the same blade stock and grind as the Sebenza. I always wondered if thats what the 25 was.
Is it that I could be rendered for oil?Yeah, but there's something fishy about him.![]()
Nope, the handle and piviot are different.Wouldn't that just be a 31?
Well, let's see...Is it that I could be rendered for oil?
Nope the Inkosi is closer to the sebbie then the 25 is.Interesting. It would be neat to see an Inkosi but with the same blade stock and grind as the Sebenza. I always wondered if thats what the 25 was.
This is one of the funniest things I've read in some time my friend... Most excellent!Well, let's see...
You're not a flipper
But you do spout off a bit
You may or may not carry a bit more blubber than you should
On the other hand most cetaceans don't submit to elective surgery...
You float...
Definitely a witch!
