Why uncoated? Non-stick pans are so much easier to clean.
Sounds like you want steel, if cast iron is too heavy. Try looking at the All-Clad Copper Core line.
http://www.lnt.com/product/index.jsp?productId=2127426
I like some of Calphalon's cookware (I'm biased towards USA made,) May I ask; why no aluminum? I've had great results with the anodized-surface stuff. Non-Nonstick, and lightweight.
Could someone please recommend a line(s) of pots/pans/skillets? I'm down to my last one of each.
I'm looking for something that is uncoated, is not made of aluminum and preferably does not weigh a ton.
Heavy cast iron makes bad apartment stoves livable too.![]()
Cast Iron. Worth it's wieght in "Iron"!![]()
I am trying to get some of the decent UK, properly made S/S kit that is not related to the sink in which it is to be washed.
There is a whole load of info if you want to surf the net. The use of wines and vinegar often leaves metalic tast (mild). Steel types are as important as blade making.
The All-Clad Copper Core is great stuff, but it's pretty expensive. you might want to consider buying individual pieces as you really need them rather than buying a "set".
