- Feb 11, 2014
Is it just marketing? because i've seen an S30V break from flexing.
All metal resists flex breakage.
Until it yields and/or breaks.
By the way...where did you see this and on what knife?
it's one of survive! knives advertising.
"CPM-20CV is a very high quality martensitic stainless steel, with outstanding corrosion resistance and excellent edge holding. CPM-20CV does lack the impact toughness of CPM-3V but being made with the CPM process, this steel is still very resistant to lateral stress (flex) breakage. Consider CPM-20CV for a very low maintenance, all weather cutting tool. "
bdmicarta made a point.
Ah yeah blades will break once the flex goes beyond a certain point.....
A lot will depend on the tempering and blade geometry on how far that will be....
Will an S7 or CPM 3V with a 10 inch blade with a hardness of 58-60 rc flex the same as a 1055 with a hardness between the high 40's and low 50's. given all had the same length and edge geometry.
We need to first define flex. Flexing is when the blade takes no permanent bend, and returns to true when pushed sideways, ie prying. The S7 and 3V at that hardness will not bend much before breaking. All three will flex the same to the point the 1055 bends, which it will before the other 2. S7 and 3V will flex further than the 1055 (in this example), but once pushed too far, they will not bend much before breaking. The S7 should have a slight edge on the 3v in flexing, but there is so much dependent on how the hardness was reached that it's not easy to make a prediction.
