- Feb 4, 2005
Aktoklat,
I don't know anything about your hammer. Sid and Keri at Little Giant will, for sure. I got a catalog reprint for Fairbanks hammers from them and they may be able to provide you with one for your hammer or point you to someone who can. One of the tables in my catalog listed max. bpm and motor hp. and belt size.
I don't think you are going to find a 2" dia. x 4" long flat belt pulley... if I understood that.
I'm curious... is your hammer a Fairbanks copy, like Little Giant, Myers, etc.? Does it have a Little Giant type clutch?... like, it runs on hard and fast belt... or is it a Fairbanks type clutch where where the belt is tightened to act as a clutch?
Is the 8" middle pulley part of the original design or an add on ?
The old hammer motors were generally low rpm types. To match spec. bpm, a person is actually better off looking for a low rpm motor rather than switching pulley sizes around. Sometimes, to match spec. bpm with a common rpm modern motor, a person needs to run a jack shaft system... especially if you either have to, or want to run a flat belt. If I hadn't run into a cheap, used low rpm motor for our Fairbanks, I would have had to do that to match the 375max. bpm. The reason is, a Fairbanks has to run a flat belt and the belt needs to be stout because its is the clutch, therefore has to be both stout and stretch free (or nearly so). About the smallest dia. flat belt pulley for a 2" belt is 4" in diam. Flat belts don't deal with sharp turns well. Looking at 375bpm and a 12.5" drive wheel and a minimum 4" dia. motor pulley, the motor would need to be 1170 rpm. With a 5" pulley, the motor speed would need to be 937rpm. Anyhow, a jack pulley system gears the existing motor speed (modern 1725-1750) down to the bpm needed... small to large and small to large. In our case, we would have run motor to #1 jack pulley as double "V" belt and #2 jack pulley to drive wheel as flat belt.
Mike
Mike
