- Jul 23, 2015
I removed my disc plans that I uploaded last year as I wanted to revise the plans. I still get people emailing me for the plans but I wanted to fix the errors before I make them available again. I have cleaned up and modified the original plans and now came up with a different version as well. I have come up with a version to use MOST base mount motors. Once I get one of the base mount grinders welded up I will post pics of it.
Both versions still require welding, cause frankly, I think if you can make knives you should know how to weld, and I am a welding instructor.
Now the files are in folders that have the individual drawings. These will not be modified or updated as I make changes. The plans work as is. I have modified some things to make them "better" in my opinion. Feel free to change stuff you want to change.
Disclaimer: I assume no liability for you using these plans to construct a machine. Disc grinders are inherently dangerous machines and you can injure yourself. By downloading these plans you assume all liability for your own actions.
About the files:
Facemountnest is facemounted only. it requires 12"x36"x1/4" steel.
Basemountnest is basemount motors only and requires 12"X40"X1/4" steel. I would wait to use these until I get one welded up and report back.
I AM NOT SELLING THESE
Modified Original face mount.
I fixed dimensional errors causing the tabs to not fit in the slots, radiused the corners and shortened the base plate. I will be coming up with a few different knobs and whatnot as well. I am no longer drawing these to be plasma cut. I am designing them with waterjet or laser cutting tolerances.
Base plates for base mount
Multi bolt pattern base mount.
Rendering of Base and Facemount
Strictly base mount. This version saves a ton of metal and I am pretty sure the parts will fit in a flat rate box now.
Base mount with a big motor just in case
About the files:
