Hi guys,
I actually registered so I could post this question, as I either didn't find it answered directly, or the threads pertaining to it were from several years back when ZT had issues with Elmax.
I'm looking at buying a few ZT 0566 models and I've found a couple in both Elmax and S35VN.
The first question I have is, which one is more corrosion resistant? I read that Elmax should be more corrosion resistant due to the higher level of Chromium; however, most all of the sites showing tests and field usage cite S30V/S35VN (I'm considering them the same for corrosion purposes) as the more corrosive-resistant steel. What gives here, and which is correct?
Secondly, I did some reading and found that, when heat treated properly, Elmax is a better overall steel than S35VN. However, in production knives, Elmax and S35VN are about the same. I also came across several threads that mentioned ZT's poor HT of Elmax (specifically burning), but it seems to have been resolved as time went on, albeit it still wasn't optimal enough to take advantage of Elmax's properties.
That is to ask, did ZT finally address their problems with burning/over-treating Elmax? Was the 0566 ever affected? If so, what serial number ranges should I be looking for?
Lastly, is there going to be any practical difference between a ZT 0566 in Elmax vs S35VN?
I appreciate it!
I appreciate it!
