What is your preferred belt grits to use pre heat treat and then post heat treat of carbon blades?
Just starting I've been using the following, let me know if I should be adding or removing any grits anywhere:
Pre HT:
36 grit Zirconia - Grind out blank
60 grit Blaze - touch up blank and start the blade grind
120 grit Blaze - take out 60 grit scratches and clean up
320 grit Gator - take out 120 grit scratches
Post HT:
120 grit Blaze to clean off scale
320 grit Gator - clean up 120 scratches
600 grit Ceramic - clean up 320 and get nice finish
For high polish move to hand sanding with finer grits.
Pre HT:
Post HT:
