- Dec 21, 2006
Carbon steel only. Stock removal only. I shape my blades first (95% done), then heat treat. I only heat treat before shaping if making thin kitchen knives, and then my question posted does not come into play. On .125 blades, I shape the bevels and then heat treat. So, to answer Rick, no I thermal cycle AFTER stock removal, immediatley before hardening. So I take a blade that is 95% shaped, 1600 1500 1400 then 1500 soak quench, or what have you. I DO sand off the scale layers between each cycle. Takes time.....yes it does. The absense of scale allowing for more decarb. Matthew, you are right....I cannot control the decarb (actually, I think a person can.....I think there are formulas that are very acurate in determining decarb thickness for a given temp/time, but I'm not too interested in it). But leaving an edge 030 or a tad thicker, going through my normalizing procedure, I get to hard steel at around 015 or so....it has always turned out perfect. Control it? to a certain extent with time and temp. But it isn't an issue for me. My heat treat works....just trying to save some time. I'll just have to try going from my smooth cut file to 220 grit directly, and see if it isn't too much more elbow grease. I get what you guys are trying to rap into my head.....I'm asking how to save time doing "x", when I'm wasting time (in a sense) doing "y" later down the road! I'll figure it out!
