Haven't been able to find just the right answer to my question...
I have the bevels filed into my first knife and have moved on to pre-HT sanding. Looking pretty good so far, definitely taken a long time. I read on the forums somewhere that I should target .030" - .040" pre-heat treat edge thickness with 1095. I'm going to make a couple more blades so I can send out for HT at the same time, and I don't want to find I made a mistake and repeated it.
Since I am hand filing should I go thinner? It seems other makers take their edges down to .020" or less before HT...but they are also using other steels.
If .030-.040" is good, then what do I do after heat treat? Do I need to take the edges down thinner before final sanding and sharpening? If so, how thin and how do I do that? I imagine after HT that the blade will be nearly file hard so progress would be slow...so that leaves sandpaper, but even now in the annealed state the material removal rate is incredibly slow.
