- Mar 8, 2008
A machete purpose-built for standing strong in uncertain times. Machetes have long seen use across the globe in times of crisis, but until now none have been designed expressly for this purpose. The distal-tapered high carbon steel blade is rigid and unyielding to pressure, and is long enough to offer advantageous reach while remaining short enough to be manageable in cramped quarters. The point of balance is just 3.5" in front of the American hickory handle, which features a full-length grip below the finger notch to accommodate small or large hands alike. Intended to be as economical as possible, so that you may feasibly afford to outfit an entire group, the Kingfisher is not furnished with a sheath, and is ripe for customization to make it uniquely yours. Currently offered at special introductory pricing for the first 200x units. As of the time of this posting, only 117x remain.
As supplied from the factory, the Kingfisher sports a nearly-finished "courtesy grind" to speed the final sharpening process for the end user. If selecting the Special Grade option we will grind and hone the forward edge so that it is ready for action right out of the box. If selecting the Special Grade Plus option we will also perform this work to the partial back edge, which is otherwise unsharpened. Made with pride in El Salvador.
Overall Length: 31"
Blade Length: 24"
Steel: 1075 High Carbon
Thickness: 3.2mm distal tapered to 1.85mm
Weight: 1lb 12oz
In hand:
